Recommendations to secure a point to point and VPN customer network
Nov 25th, 2008
Hello. We have a network of costumers with 2 mb links over ethernet and over VPN too. They can see our windows servers ( they have to ) to connect to our services. The question now is: If they are using M.S windows clients ( hosts ) that are connected to the internet, are they dangerous to our network ? Beside filtering traffic, to only give access to certain hosts what more do you recommend ? The servers are windows too. Are we in danger because of the possible infections of our costumers ¿? What is the beet approach to this ?
cisco24x7 Tue, 11/25/2008 - 09:57
  • Silver, 250 points or more
You need to have host IDS/IPS on the windows
servers and also network IDS/IPS at the point
of entry after the traffics are decrypted to
catch worms and viruses
ariesc_33 Wed, 11/26/2008 - 19:34
is the connection on the ethernet a private network? and VPN is in used over the internet connection? if os, then, there will no security issue but i suggest you harden the network by having access-list that only allows specific services required from the hosts then everything else is blocked.
