11-25-2008 09:32 AM - edited 03-04-2019 12:29 AM
interface Serial2/0
no ip address
encapsulation frame-relay IETF
clockrate 1008000
frame-relay lmi-type ansi
frame-relay intf-type dce
frame-relay route 102 interface Serial2/1 201
end
Router(config-if)#do sh run int ser2/1
Building configuration...
Current configuration : 194 bytes
interface Serial2/1
no ip address
clockrate 1008000
frame-relay route 201 interface Serial2/0 102
Status is inactive
thanks
11-25-2008 10:20 AM
hello Arum,
have you configured
frame-rel switching
in global config ?
and the
sh int ser2/0
sh int ser2/1
what provides
Hope to help
Giuseppe
11-26-2008 06:32 AM
have you tried to lower the clockrate ?
For my lab I used this configuration and it works:
frame-relay switching
interface Serial0/0
description Connected to Rack1R1
clockrate 64000
frame-relay route 102 interface Serial0/1 201
interface Serial0/1
description Connected to Rack1R2
clockrate 64000
frame-relay route 201 interface Serial0/0 102
12-01-2008 04:07 AM
Your Question is incomplete
Exactly what you want
Check the Clock Rate as your's ISP Provide
