Guest complaining of dropping signal Cisco 1131
Nov 25th, 2008
I manage a hotels wireless internet and i get constant complaints from guest saying they are getting kicked off wireless. On for 5 to 10 minutes and then they get " page can't be displayed" then after a few minutes they connect again. Do you see any issues with my config ?
here is my template config...channelization is good andmy site survey shows excellent coverage
! AP1131-1
no service pad
clock timezone GMT -6
clock summer-time GMT recurring
ip domain-name xyz
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname AP1of10
ip subnet-zero
logging on
logging buffered 4096 informational
dot11 vlan-name Management vlan 7
dot11 ssid hooters
vlan 319
authentication open
guest-mode
power inline negotiation prestandard source
no username Cisco
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
no shutdown
ssid hooters
speed 1.0 2.0 5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
no preamble-short
channel 1
station-role root fallback shutdown
rts threshold 2312
rts retries 10
interface Dot11Radio0.319
encapsulation dot1Q 319
no ip route-cache
bridge-group 254
bridge-group 254 subscriber-loop-control
bridge-group 254 port-protected
bridge-group 254 block-unknown-source
no bridge-group 254 source-learning
no bridge-group 254 unicast-flooding
bridge-group 254 spanning-disabled
interface Dot11Radio0.7
encapsulation dot1Q 7 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
shutdown
interface FastEthernet0
no ip address
no ip route-cache
duplex full
speed 100
hold-queue 160 in
interface FastEthernet0.319
no ip route-cache
bridge-group 254
interface FastEthernet0.7
no ip route-cache
bridge-group 1
interface BVI1
ip address 10.1.1.2 255.255.255.192
no ip route-cache
ip default-gateway 10.1.1.1
ip http server
no ip http secure-server
ip http authentication local
control-plane
bridge 1 route ip
line con 0
login local
transport preferred all
transport output all
line vty 0 4
login local
transport input all
line vty 5 15
login local
transport input all
crypto key generate rsa
1024
end
gamccall Tue, 11/25/2008 - 11:42
  • Silver, 250 points or more
The only thing that really jumps out at me from teh config is a little bit of surprise at your basic-11 setting. If your coverage is good enough that everyone's connecting at 11Mbps consistently, then you should disable the slower rates; if people do end up connecting at slower rates, then the basic rate should be the slowest one they do connect at.
However, intermittent drops tend much more often to be coverage or interference problems than the AP configs. Or perhaps an issue with your captive portal solution, if you're using one.
wesleyterry Wed, 11/26/2008 - 12:45
  • Bronze, 100 points or more
I don't have any experience with the autonomous APs, but I know on the controllers that I have problemd with my Guest SSIDs that have web authentication only. There is a Session Timeout setting on the controllers that sets the interval for re-authentication.
And when doing web-based authentication, then the user must go through the web-authentication page again for the wireless to work once the session timeout is reached. In my scenario, the web authentication page wouldn't come up unless the user manually disconnected and reconnected (or potentially closed IE and started it again). This gave the appearence that they were disconnected with the page cannot be displayed messages.
But this may not be relevent in your case since it isn't controller based and I'm not sure if you use web authentication.
However, a good test would be to see if the WIRELESS disconnects or if it is just merely that data is no longer passing on the active connection.
