CCM/CUCM - Alpha Call ID
Answered Question
Nov 25th, 2008
  • Silver, 250 points or more
Is it possible to set the Call ID name for outbound calls from CCM/CUCM. I've read that the Alerting Name on a device's line specifies the Call ID name, but am looking for clarification.
Obviously, this depends on our carrier passing whatever we send them which they don't typically do for the name but can do for the number up on request. At least in the US.
thanks,
Will
Correct Answer by Jaime Valencia about 8 years 8 months ago
yes, it's the alerting name
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Jaime Valencia Tue, 11/25/2008 - 13:08
  • Cisco Employee,
  • Hall of Fame,
    2011
yes, that's correct. just go to the GW config in CUCM and check
"Display IE delivery"
also as you already noted not all Telcos have this capability so best check with them before doing any changes in CUCM
java
will.alvord Tue, 11/25/2008 - 13:11
So check "Display IE Delivery" to allow, but where is it set? In the "Alerting Name" on the device lines?
Jaime Valencia Tue, 11/25/2008 - 13:15
  • Cisco Employee,
  • Hall of Fame,
    2011
as i mentioned, under gateway config on CUCM
java
will.alvord Tue, 11/25/2008 - 13:16
Right. I understand. But where is the actual call id name value set? In the "Alerting Name" field on the phone lines?
thanks,
Will
Correct Answer
Jaime Valencia Tue, 11/25/2008 - 13:21
  • Cisco Employee,
  • Hall of Fame,
    2011
java
