Problem in the integration of CWLMS with the ACS
Answered Question
Nov 25th, 2008
Performing the integration of CWLMS 3.0 with the ACS 4.1 appliance, access to the portal be very slow, the integration was sucesfull and the modules operate correctly.. the problem is the slowness..
Reviewing the traffic between them i found that CWLMS try netbios connections with the ACS.. many of them .. and that delay .. i think..
I think that there is the problem..
Sorry for the english..
Any idea?
Correct Answer by Joe Clarke about 8 years 3 months ago
If LMS is running on Windows, add an entry for the ACS server into the LMS server's local hosts file. For example:
10.1.1.1 acs
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Tue, 11/25/2008 - 11:13
10.1.1.1 acs
