Traffic-Shape or Policy-Map
Nov 25th, 2008
Hi Experts! I am trying to configure bandwidth control (only ICMP) in a ROUTER but in "both" ways. From PCA to PCB I want to configure 200K, and from PCB to PCA I want to configure 400K. This configurations are done because I want to avoid excessive traffic that can be increase the process of my router. There is other kind of traffic passing through these interfaces must not controlled:
PCA ----> G1/1 ROUTER G2/2 ----> PCB
PCA <---- G1/1 ROUTER G2/2 <---- PCB
1.- What is better? traffic-shape or policy-map?
2.- If I use traffic-shape, in wich interface do I must apply?
3.- If I use policy-map, in wich interface do I must apply?
4.- Is the following configuration correct?
PCA=10.10.10.10, PCB=20.20.20.20
access-list 110 remark LIMIT PCA to PCB
access-list 110 permit udp host 10.10.10.10 host 20.20.20.20 eq snmp
interface G2/2
traffic-shape group 110 200000
access-list 120 remark LIMIT PCB to PCA
access-list 110 permit udp host 20.20.20.20 host 10.10.10.10 eq snmp
interface G1/1
traffic-shape group 120 300000
Normally, traffic-shape is used in the outside of the interface, but with this, there is passing a lot of traffic to the router. With "policy-map" is more efficient? Can you send me an example please?
Thanks for your help!!!
Edison Ortiz Tue, 11/25/2008 - 14:11
  • Hall of Fame,
    Founding Member
With MQC (Modular QoS CLI), you get more options within the shaping mechanism.
First, you create a class-map where you can match against an ACL (just like you've done above) or using NBAR among other things.
Here is the list of options under class-map:
match ?
access-group Access group
any Any packets
class-map Class map
cos IEEE 802.1Q/ISL class of service/user priority values
destination-address Destination address
discard-class Discard behavior identifier
dscp Match DSCP in IP(v4) and IPv6 packets
fr-de Match on Frame-relay DE bit
fr-dlci Match on fr-dlci
input-interface Select an input interface to match
ip IP specific values
mpls Multi Protocol Label Switching specific values
not Negate this match result
packet Layer 3 Packet length
precedence Match Precedence in IP(v4) and IPv6 packets
protocol Protocol
qos-group Qos-group
source-address Source address
Once you have a match, you can shape the target traffic under a policy map, the shape command also offers more options that the command above:
shape ?
adaptive Enable Traffic Shaping adaptation to BECN
average configure token bucket: CIR (bps) [Bc (bits) [Be (bits)]], send out Bc only per interval
fecn-adapt Enable Traffic Shaping reflection of FECN as BECN
fr-voice-adapt Enable rate adjustment depending on voice presence
max-buffers Set Maximum Buffer Limit
peak configure token bucket: CIR (bps) [Bc (bits) [Be (bits)]], send out Bc+Be per interval
An example would be like:
class-map PCB<->PCA
match ip access-group 120
policy-map PCB<->PCA
class PCB<->PCA
shape average 300000
interface g1/1
service-policy output PCB<->PCA
HTH,
__
Edison.
Please rate helpful posts
Joseph W. Doherty Wed, 11/26/2008 - 03:58
I think you post raises 3 issues.
Whether to use older or newer shaping syntax.
Whether to shape or police (not actually asked).
Whether either will avoid extra traffic increasing processing to the router itself.
For the first issue, like Edison, I would recommend the newer policy-map syntax. Likely where the old and new syntax overlap in function, the same IOS code might support both, but the policy-map allows many additional featurs.
For the second issue, shaping queues traffic that exceeds the bandwidth limit and I think it can only be applied in an outbound direction. Policing, however, drops overspeed traffic and can be applied inbound. Since the shaping might only regulate outbound speed, and it still needs to contend with inbound traffic, it may not offer as much reduction to router load as policing may. Policing, though, since it does drop packets, might adversely impact the SNMP applications.
Your third issue, avoiding loading the router, might be somewhat difficult to accomplish with either shaping or policing. If there's so much traffic passing through the router, that the volume is more than the router can process, neither shaping or policing within the same router may offer enough relief. I'm unsure the impact either might have, since usage of additional QoS features tend to increase router load. However, of the two approaches, policing traffic as it immediately enters the router, I would suspect, would offer the most load reduction benefit, if there is one.
Below are example of both policing and shaping using policy maps. (I'm assuming we're using a router and not a L3 switch, and the IOS is of recent vintage. Also, my syntax might be off.)
class-map match-all yourClass
match protocol SNMP (I think that's in NBAR)
(shaping)
policy-map shapePCA2PCB
class yourClass
bandwidth 200
shape average 200000
policy-map shapePCB2PCA
class yourClass
bandwidth 400
shape average 400000
interface g2/2
service-policy out shapePCA2PCB
interface g1/1
service-policy out shapePCB2PCA
*or*
(policing)
policy-map policePCA2PCB
class yourClass
police average 200000
policy-map policePCB2PCA
class yourClass
police average 400000
interface g1/1
service-policy in policePCA2PCB
interface g2/2
service-policy in policePCB2PCA
