Remote VPN access (PPTP)
Nov 25th, 2008
I have created a Vpdn connection in the router with the IOS of : IOS (tm) 3600 Software (C3660-IK9O3S-M), Version 12.3(1a)
for the remote VPN users i have given MSchap as the authentication
our problem is users using the windows VISTA as a operating system cannot able to access the remote VPN but the users using Windows XP able to LOGIN
Please suggest me for the above issue
Vinoth
sachinraja Tue, 11/25/2008 - 13:29
  • Red, 2250 points or more
Hello vinoth
Are you getting any errors on the router ? did you do a debug ? If it connects with XP, i dont think there will be any configuration errors on the router.. It might just be a OS support issue on this particular version of the Cisco IOS software.. refer to release notes and see if there are any limitations..
In the mean time I saw this URL.. Might help you setting up VPDN on vista..
https://www.publicvpn.com/support/Vista.php
Hope this helps.. all the best.. rate replies if found useful..
vinoth.kumar Wed, 11/26/2008 - 01:41
Thanks for your reply
since we are using router ios for connecting remote VPN is there any problem on this
I have done same configuraion as like XP OS but i not able to connect from VISTA
Vinoth
