Cannot access devices on a vlan however the devices can access the switches
Answered Question
Nov 25th, 2008
This is probably a quick fix, however I am baffled. I have set up 2960 switches with a vlan of 10 for access and vlan 1 for trunking. I can ping and access all my switches from any other switch. I can access the switches from the device on an switch port however I cannot access the device from the switch. Is there something I am missing in the port configuration. Here are some of the configurations on the switch:
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/1
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
interface Vlan10
ip address xxx.xxx.53.219 255.255.254.0
502-NSW-1#show spann vlan 10
VLAN0010
Spanning tree enabled protocol ieee
Root ID Priority 32778
Address 001d.e68e.e000
Cost 19
Port 25 (GigabitEthernet0/1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32778 (priority 32768 sys-id-ext 10)
Address 0024.1319.ed80
Aging Time 300
Interface Role Sts Cost Prio.Nbr Type
Fa0/1 Desg FWD 19 128.1 Edge P2p
Gi0/1 Root FWD 19 128.25 Shr
Gi0/2 Desg FWD 4 128.26 P2p
If there is anything else to see, let me know
Correct Answer by glen.grant about 8 years 6 months ago
Where is the routing being done ? Sounds like the trunk is not working correctly.
Overall Rating: 5 (1 ratings)
Correct Answer
glen.grant Tue, 11/25/2008 - 13:19
  • Purple, 4500 points or more
Mark Yeates Tue, 11/25/2008 - 13:19
  • Gold, 750 points or more
I would remove the "switchport access vlan 10" command from Gi0/2. If this does not work please post the full (sanitized) configs.
HTH,
Mark
John Blakley Tue, 11/25/2008 - 13:21
Do you mean that you can't ping the device that is connected to the switchport? Firewall enabled on the host?
John
