Unity Connections Reset passwords everyday
Answered Question
Nov 25th, 2008
I have a fresh install of unity connections. the version is 2.1.0.9901-362.
All of the users on it have to reset thier passwords every day when they log into the voice mail. I can't figure out what is wrong.
Thanks in advance
Correct Answer by Jaime Valencia about 8 years 3 months ago
CSCsk70776
password set to never expires but Connection asking to change password
Symptom:
system settings -> authentication rules -> "never expires" causes Unity connection to ask for the cuaadmin admin password to be changed daily. Expectation is that the cuaadmin password never expires when this is selected.
Conditions:
Unity Connection 2.x
Workaround:
Set to expire in 365 days
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Bradford Magnani Tue, 11/25/2008 - 14:16
Erik,
System Settings > Authentication Rules > Recommended Voice Mail Authentication Rule, and check "Credentials Expires After". This may be set to 1 day.
Hope this helps. If so, please rate.
Brad
erikjustinlee Tue, 11/25/2008 - 14:19
Yep, that is the first place I checked. It is set with the check box to never expire.
Correct Answer
Jaime Valencia Tue, 11/25/2008 - 14:41
CSCsk70776
Symptom:
Conditions:
Workaround:
java
