Certifictae for Controller
Nov 25th, 2008
Is there a way to download the certificate for the controller so internet explorer will not continue to give the annoying message that the certificate is from an untrusted source?
wesleyterry Tue, 11/25/2008 - 21:20
I think the only option is to get a certified certificate from a 3rd party authority. This would allow every computer to automatically trust the cert if that is what you are aiming for.
To upload the 3rd party cert In the GUI, go to:
Management > HTTP
This is where the HTTPS certificate is managed.
If you have a 3rd party certificate from a CA, I believe you click Delete Certificate, then click the Download SSL Certificate and fill in the tftp details.
It required a reboot for the certificate to take effect.
This config guide explains in more detail the installation process... http://www.cisco.com/en/US/docs/wireless/controller/5.1/configuration/guide/c51intf.html#wp1101169
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
