2 Default routes on same router with 2 Leased line from 2 service providers
Nov 25th, 2008
Hi ,
Can i load balance over 2 Leased lines with same characteristics with 2 defaults routes over these 2 links from different service providers ?
vimalkumars Tue, 11/25/2008 - 23:55
Hi Friend ,
Thank you for reply . I have both Dedicated circuits with same BW and other characteristics ( From same service provider ) terminated on same router with 2 default routes over these circuits . as below configuration . No routing protocols configured
ip route 0.0.0.0.0.0.0.0 int se0
ip route 0.0.0.0.0.0.0.0 int se1
If it load balances over these 2 links , Can you please explain how ?
vassiliev Wed, 11/26/2008 - 00:18
If you have 2 dedicated circuits, I suggest you can use multilink.
Ex:
int multilink 10
en ppp
ip address x.x.x.x y.y.y.0
int s1/0
en ppp
ppp multilink group 10
no shut
int s2/0
en ppp
ip route 0.0.0.0 0.0.0.0 multilink 10
It will use two circuit for your network.
Hope help you~!
Best Regards
Cheng
vimalkumars Wed, 11/26/2008 - 00:23
Hi Cheng ,
Thank you ..
I misunderstood our situation . Actually we have 2 dedicated circuits with same BW and characteristics from different service providers for the same destiantion .
Can we load balance by configuring 2 default routes on these 2 circuits ?
Vimal
vassiliev Wed, 11/26/2008 - 00:30
Yes, you can do this.
But something risks in this. Because these ISP delay is not same.
If you do this, please advisement circuit delay~! It is very important for this.
ariesc_33 Wed, 11/26/2008 - 00:27
with static routes, there will be two equal cost paths and your router will load balance between them.
the issue here is that when static routing is in use, when the other link is down, your router will still use or advertise that route.
the solution here is to implement ip sla to monitor the status of the interface or the link.
ariesc_33 Wed, 11/26/2008 - 00:40
using icmp to monitor the link status
track 10 rtr 1 reachability
track 20 rtr 2 reachability
ip route 0.0.0.0 0.0.0.0 1.1.1.1 track 10
ip route 0.0.0.0 0.0.0.0 2.2.2.2 track 20
ip sla 1
icmp-echo 1.1.1.1 source-ip 192.168.1.1
timeout 1000
threshold 50
frequency 1
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 2.2.2.2 source-ip 192.168.1.1
timeout 1000
threshold 50
frequency 1
ip sla schedule 2 life forever start-time now
