2960 switch problem
Nov 25th, 2008
Hi all,
I m facing the problem in reloading the IOS in switch by Xmodem.When i m trying to access the rmode then mesg is displayed "Access is denied".
Full message is given below:
C2950 Boot Loader (C2950-HBOOT-M) Version 12.1(11r)EA1, RELEASE SOFTWARE (fc1)
Compiled Mon 22-Jul-02 17:18 by antonino
WS-C2950G-48-EI starting...
Base ethernet MAC Address: 00:0b:46:e5:b2:00
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 1 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 1536
flashfs[0]: Bytes available: 7739904
flashfs[0]: flashfs fsck took 4 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading ""...: permission denied
Error loading ""
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
switch: boot
Error loading ""
switch: copy xmodem c2950-i6q4l2-mz.121-12c.EA1
xmodem: permission denied
switch: copy xmodem c2950-i6q4l2-mz.121-12c.EA1 bin
switch:
The system has been interrupted prior to initializing the
flash filesystem. The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
flash_init
load_helper
boot
switch: set
switch: unset
usage: unset <variables...>
switch: unset boot
Variable boot" not set, or is readonly.
switch: unset manual_boot
Variable manual_boot" not set, or is readonly.
switch:
royalblues Wed, 11/26/2008 - 01:47
Have you initialised flash before the xmodem process?
flash_init
load_helper
Narayan
