Using a RADIUS Server to Assign Users to VLANs
Nov 26th, 2008
  • Bronze, 100 points or more
Is this possible on autonomous access points? http://www.cisco.com/en/US/docs/routers/access/1800/wireless/configuration/guide/s37vlan.html#wp1038739
I try to set this up but it does not work. I have 2 SSIDs, "Test1" defined on VLAN 10 and "Test2" on VLAN 99. Everything works fine if the RADIUS server does not send the VLAN attributes or if it sends the matching VLAN attributes. However, if I try to connect to "Test1" and the RADIUS server wants to assign the user to VLAN 99 instead, I see "one-way traffic". First the computer successfully authenticates and associates with the access point. If I check with "show dot11 associations all-client" I can see the client is associated and assigned to VLAN99. However, now the computer will request an IP address with DHCP. The DHCP server receives it as usual and will respond with a DHCP OFFER. However, the DHCP OFFER never makes it to the wireless client. If the client connects to "Test2" instead it will work immediately. All other examples for dynamic VLAN assignments I have found so far use LWAPPs und a controller. Is this possible with autonomous APs?
Abridged config:
dot11 vlan-name Test vlan 10
dot11 vlan-name Test2 vlan 99
dot11 ssid Test
vlan 10
authentication open eap eap
authentication network-eap eap
authentication key-management wpa
guest-mode
mbssid guest-mode
dot11 ssid Test2
vlan 99
mbssid guest-mode
interface Dot11Radio0
no ip address
encryption vlan 99 mode ciphers aes-ccm tkip
encryption vlan 10 mode ciphers aes-ccm tkip
ssid Test
ssid Test2
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.10
encapsulation dot1Q 10
no cdp enable
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 spanning-disabled
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
interface Dot11Radio0.99
encapsulation dot1Q 99
no cdp enable
bridge-group 99
bridge-group 99 subscriber-loop-control
bridge-group 99 spanning-disabled
bridge-group 99 block-unknown-source
no bridge-group 99 source-learning
no bridge-group 99 unicast-flooding
Gerald Vogt Tue, 12/02/2008 - 14:05
Thanks for the link. But the section only links to another page which contains exactly the same description which I have posted before. I know all that. I can't see anything there which I should do different.
Do you use it yourself? Do you have autonomous APs using RADIUS based VLAN assignments?
tpereirahpts Sun, 02/08/2009 - 15:07
I have an autonumous access point AIR-AP1252AG-E-K9 with firmware version 12410JA. I have only one SSID and multiple VLANs that can be assigned by the attributes delivered by a RADIUS server.
The users authenticate OK and I see the DHCP discover arrive to the DHCP server but the DHCP offer doesn't arrive to the wireless client.
How you solve the DHCP problem?
Gerald Vogt Sun, 02/08/2009 - 16:33
Are you sure you don't have multiple BSSID enabled?
tpereirahpts Sun, 02/15/2009 - 03:34
Yes I don't have multiple BSSID enabled.
Apparently the problem was solved with a AP reboot.
Thanks.
fernandoaguirre Tue, 03/10/2009 - 15:46
Can you please send me the configuration of the AP for only one SSID and multiple VLANs that can be assigned by the attributes delivered by a RADIUS server?
I have the ACS Server dynamically assigning the vlans but I get an authentication error on the AP.
Gerald Vogt Tue, 03/10/2009 - 16:44
What error do you get exactly on the AP?
Generally, I only got authentication errors on the AP if the authentication was in fact incorrect. Does the log of the ACS server show that the users is successfully authenticated?
The configuration which I have posted initially does work if you don't have MBSSID enabled (i.e. use "no dot11 mbssid" to make sure).
fernandoaguirre Tue, 03/10/2009 - 17:44
Thanks Gerald... I have the config working now. It was a problem with the dhcp for that vlan and not the ap config.
Regards.
r.spiandorello Tue, 03/17/2009 - 07:26
Hi, in case of difference between the pc ssid and ACS assigned ssid, where can I find the mismatch log ? AP syslog ?
thank you in advance
fernandoaguirre Tue, 03/17/2009 - 13:19
I understand that the ACS assigns the vlan id or name, but not the ssid.
The SSID is between the PC and the AP.
Gerald Vogt Tue, 03/17/2009 - 14:47
Which mismatch? If the SSID on the PC is different from the SSID on the AP the PC won't connect. There is no log for that. The PC just won't find any wireless network to connect to.
Trending Topics - Security & Network
