Controller console port on 3750 with WLC
Nov 26th, 2008
What hyperterminal settings are required to access the Controller console port on a 3750 with integral WLC? I think I have exhausted all possibilities but still cannot access it
Rob Huffman Wed, 11/26/2008 - 06:16
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Steve,
Command-Line Interface
You can enter Cisco IOS commands and parameters through the CLI. Access the CLI either by connecting your PC directly to the switch console port or through a Telnet session from a remote PC or workstation.
Follow these steps:
1. Connect the supplied RJ-45-to DB-9 adapter cable to the standard 9-pin serial port on the PC. Connect the other end of the cable to the switch console port.
2. Start a terminal-emulation program on the PC.
3. Configure the PC terminal emulation software for:
-9600 baud
-8 data bits
-No parity
-1 stop bit
-No flow control
Catalyst 3750 Integrated Wireless LAN Controller Switch Getting Started Guide
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/hardware/quick/quick3750g/guide/3750GSG3.html
Hope this helps!
Rob
s-moynihan Wed, 11/26/2008 - 08:38
Hi Rob,
Thanks for the response. I tried 9600 8None1 first but got no response. I then tried various other speeds but still no response from the controller. I accessed the switch ok via the console port. Apparently you can then connect to the controller using the 'session 1 processor 1' command, but this does not work either. This failed with a message stating something like 'telnet access not allowed to this device'.
Rob Huffman Wed, 11/26/2008 - 10:16
  • Hall of Fame,
    Founding Member
Hi Steve,
If you have a look at the Express Setup portion of the doc I linked you can see how to enable Telnet access :)
Hope this helps!
Rob
