How to configure cisco switches to connect alcatel phones and pcs?
Nov 26th, 2008
one of our customers plans to connect alcatel ip phones "ip touch 4038" (with pcs connected to the phones) to cisco Cat4500 switches. Also normal pcs should be connected directly to the 4500.
So I think the phones would be connected with vlan trunk and the pcs with normal access port configuration.
To insure an easy switch administration we are looking for one (!) common switchport configuration which allows the connection of phones and also pcs. As far as I know with cisco phones we could use dtp so that the switchports dynamically uses trunk or access configuration depending on the connected device (phone or pc).
Does anybody know how we can fulfill this requirement with alcatel phones?
If there exist best practise documentation concerning ip phones (trunks, voice vlan etc.) it would also be fine if somebody could tell me the url.
Many thanks in advance,
Thorsten Steffen
Overall Rating: 2.5 (2 ratings)
alig.norbert Wed, 11/26/2008 - 11:33
Hi Thorsten,
The IP-phone has to have a setting to configure the Voice VLAN-ID.
The voice traffic will then be dot1q-tagged (trunk). The connected PC will be transfered to the switch as native vlan.
Config for the switch-port:
interface fast0/10
switchport access vlan
switchport mode trunk
switchport native vlan
Greets,
Norbert
thorsten.steffen Wed, 11/26/2008 - 23:16
Hello Norbert,
as I wrote we also will connect pcs directly to the switch without phones between switch and pc.
Does you configuration
interface fast0/10
also work when a pc (which does not support 802.1q) is directly attached to the switchport?
Best Regards,
Thorsten Steffen
alig.norbert Wed, 11/26/2008 - 23:34
Hi Thorsten,
When the pc is directly connected on the switch, it will use the switchport native vlan or switchport access vlan because it's not tagging (no dot1q).
Here a sample that we used for connecting a SNOM-SIP IP-Phone with a connected PC. This work as well for a pc directly connected (on the switch):
(vlan 16 is the pc vlan)
interface FastEthernet0/1
switchport access vlan 16
switchport trunk native vlan 16
mls qos trust cos
spanning-tree portfast
Greets,
Norbert
thorsten.steffen Mon, 12/01/2008 - 02:29
Hello Norbert,
thank you for your explanation.
I tested the switchport configuration and it worked fine, both for a phone (with pc behind it) and for a pc. It worked also without the "switchport access vlan" command, I assume because for the switch it's always a trunk regardless what's connected.
So my test configuration looks like the following:
vlan 10
name pc-vlan
vlan 100
name voice-vlan
int fa0/1
switchport trunk native vlan 10
switchport trunk allowed vlan 10,100
swithport mode trunk
I also took some traces on the pc with wireshark in both setups and I found out some issues.
Setup 1: PC is connected at the phone
-> On the pc I get tagged broadcast traffic from the voice vlan. Perhaps my phone configuration is wrong; I checked the configuration but the only vlan parameters I can configure are
- activating vlans
- choose one vlan number
- activating the strict vlan option
So is it correct that the phone forwards voice vlan broadcasts to the pc port?
Setup 2: PC is connected directly at the switchport
-> Because the switchport is configured for tagging the voice vlan, all broadcast traffic (e.g. arp, stp) of the voice vlan is sent out of this port. So there is some unnecessary overhead now on this switchport. Did you already consider this issue?
Best Regards,
Thorsten Steffen
alig.norbert Mon, 12/01/2008 - 04:38
Hi Thorsten,
Actually, I've never traced the traffic on such a setup.
But I guess;
Setup 1; on the phone there can't be configured a vlan on the pc-port (phone works like a switch).
On setup 2; have you tried only the command "switchport trunk allowed vlan 100"?
Greets,
Norbert
