QoS on 6509 running native IOS
Nov 26th, 2008
Hi to all,
we have a couple of Catalyst 6509 with SUP720 and SUP720B running native IOS (Version 12.2(33)SXH2) and (Version 12.2(18)SXF1)
All switches have the WS-X6748-GE-TX line cards.
Now, for the WAN connection between the branch offices i've configured the switchports as a routing-ports.
We have aprox. 40 IP phones in each location (non Cisco phones)
On layer 2 (the access layer) we have Catalyst 2950. On each switchport where the IP phones are connected, the mls qos trust dscp command is active.
Now, i also want to implement QoS on the Layer 3 ports. What i've tried till now:
class-map match-any VoiceClassMap
match ip dscp ef
match access-group 199
policy-map VoicePoliMap
class VoiceClassMap
priority 1000000
access-list 199 permit ip 172.18.1.0 0.0.0.255 any
access-list 199 permit ip any 172.18.1.0 0.0.0.255
As soon as i try to bind the policy on that Layer 3 interface i get the following error:
priority 1000000 priority command is not supported in output direction for this interface Configuration failed!
So after spending couple of hours reading documetations, forum posts etc etc i'm on the verge to go crazy.
I've found out that LLQ on this linecards are not suported.
So my question is simple: how can i use QoS on these Layer 3 switchports (with the hardware mentioned above) so that VoIP traffic gets priorized to use 1Mbit of the available 100MBit Link speed.
A configuration example would be so great!!
Thank you
