How I can hide internal number? CUCM 6
Nov 26th, 2008
Forexample I want to display Unknown message only.
allan.thomas Wed, 11/26/2008 - 03:22
If you require the calling party number or name service to be restricted when dialing another internal called party, then you will need to configure a specific translation rule which is matched in your calling party's CSS when the outgoing call is made.
Refer to the Translation pattern configuration for Calling Line and Name presetation restriction:-
Hope this helps.
Allan. Wed, 11/26/2008 - 05:56
I am speaking about HIDING number, with somethikng like "Unknown". It's not similar that CSS accesses
Ayodeji oladipo... Wed, 11/26/2008 - 08:21
You can achieve this by doing the following:
1. Go to the gateway in question, scroll down to "call routing information-outbound calls"
2. Change the "calling party number presentation to Restricted
3. change the Calling party IE number type unknown to Unknown.
Hope this helps
