CSM and CWLMS.. integration?
Nov 26th, 2008
I have CSM and CWLMS servers implemented in the network, i need
to integrate the common services modules of both.. There is a possibility?
Somenthing of Multi-Trust Server..
And for the license of CS module of CSM..
CSM 3.2 (CS 3.0.1)
CWLMS 3.0 (CS 3.1.1)
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 11/26/2008 - 09:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can integrate the DCRs of these two servers as well as setup Single Sign-On between the two. The LMS server must be the DCR master and SSO master since it is running the latest version of Common Services. DCR master/slave can be configured under Common Services > Device and Credentials > Admin > Mode Settings. See the context-sensitive help there for more details on the prerequisites.
Single Sign-On can be configured under Common Services > Server > Security > Single Sign-On Setup. Again, see the help for more details.
marcoriosbazan Wed, 11/26/2008 - 09:37
hmm.. thank you...
I have the ACS integrated with the CSM and the CWLMS too.. and both possess Common Services ..
I like to divide the permits ..
For example:
The administrator of CWLMS is not the Administrator of CSM, but in "Shared Profile Components" on the ACS, Exist only one Common Services .. I can not split them?
THanks!
