EIGRP not forming adjacency
Nov 26th, 2008
Hi, I have an issue on an ATM router were the EIGRP adjacency are only forming in one direction.
The design is a hub and spoke, point to multipoint. The remote sites connect to the head end router via sub interfaces on the head end router. The issue I am seeing is that the remote site see the head end router as an EIGRP neighbour, however the head end router does not see the remote site as a neighbour, and as such no routing updates are passed.
The strange thing is, if I reboot the router, the EIGRP works fine until the Head end router's ATM drops
The config from the Head end router is
interface ATM0/0/0.30 multipoint
pvc 30/33
encapsulation aal5mux ppp Virtual-Template1
pvc 30/34
pvc 30/35 etc for all the sites
interface Virtual-Template1
ip unnumbered Loopback1
no peer default ip address
ppp authentication pap
Interface Loopback1
description ***Remote Sites WAN Interface***
ip address 192.168.227.1 255.255.255.0
router eigrp 1
redistribute connected
network 192.168.200.0
network 192.168.227.0
no auto-summary
The Config from the remote site ADSL router is
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode ansi-dmt
interface ATM0.1 point-to-point
description **To Augres**
no snmp trap link-status
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface ATM0.2 point-to-point
pvc 0/39
dialer pool-member 2
interface Vlan1
ip address 192.168.25.1 255.255.255.0
hold-queue 100 out
interface Dialer1
bandwidth 512
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username xxxxx password xxxx
router eigrp 1
network 192.168.25.0
network 192.168.229.10 0.0.0.0
auto-summary
eigrp stub connected summary
Giuseppe Larosa Wed, 11/26/2008 - 04:22
  • Hall of Fame,
    Founding Member
Hello Richard,
the remote site is point-to-point while the hub has a multipoint interface
I think for each pvc you need on the hub
pvc 30/34
protocol ip remote-side-loopback broadcast
this allow the router to map also EIGRP multicast hellos to the neighbors(s)
Hope to help
Giuseppe
richard.jackson Wed, 11/26/2008 - 07:48
Hi Giuseppe,
Thanks for the reply. Though it hasn't resolved the issue it has pointed me in the right direction to the underlying fault.
If I multicast ping from the head end router to the remote site, I get a reply back from all the remote sites. However if I carry out the same from the remote site I do not set any replies!.
Any other thoughts?
Giuseppe Larosa Wed, 11/26/2008 - 08:14
  • Hall of Fame,
    Founding Member
Hello Richard,
another possible option to get rid of multicast hellos is to use the neighbor command so that unicast messages are exchanged.
This is also a way to detect if the problem is with the multicast nature of Hellos
under router eigrp add
on hub
a neighbor ip-address for each remote
on remote
a single neighbor statement for hub
Hope to help
Giuseppe
