UCCE Installation : Domain Access
I created OUs on the AD using DomainManager. But when I start Install ICM, I could not see the domain, in the drop down list when I try to add the instance.
Server in associated to the domain, and I loggedin using domain admin account.
The msg I am getting is,
Could not find domain with CISCO ROOT OU
Anyone faced this tpe problem?
Rgds
Vijay
Zin.Karzazi Wed, 11/26/2008 - 04:05
  • Silver, 250 points or more
I assume this is IPCC Enterprise 7.x. First thing you need to do is to add the user you are logged in with to the local Administrators Groups. Can you ping the DNS server? try opening the "Active Directory users and Computers" see if everything is ok.
Also Check the Eventviewer for Errors.
david.macias Wed, 11/26/2008 - 10:03
  • Blue, 1500 points or more
when you run setup the first time make sure you're doing it with domain admin rights. Once installed you can go with a local admin rights if you need to run setup again.
david
