MPLS L2 VPN on 2 trunk Port
Nov 26th, 2008
I have a 7606 and Me3400 switch both are connected on fiber. SFP on ME and Gbics on Cisco 7606 router. ring protection.
20 VLAns are allowed in this trunk. Can I initiate L2 VPN from VLANs ? as now there are 2 physical ports in use. Normally xconnect command works on single interface or sub interface.
smalkeric Tue, 12/02/2008 - 11:44
To create Layer 2 VPN connections between two ports on the same router, use the connect command in global configuration mode. To remove such connections, use the no form of this command.
connect connection-name interface [dlci | pvc | pvp] interface [dlci | pvc | pvp] [interworking ip | ethernet]
Refer the below URL for more information:
