ASA log
Nov 26th, 2008
hi, i have configured syslog server and it is working fine, i want only specific logs on my syslog server i.e vpn user login time and logout time only. don't want any thing else. How can i configure it.
John Blakley Wed, 11/26/2008 - 04:18
You'll find the message in your syslog like:
Nov 26 2008 05:03:49 Athena : %ASA-6-302015: Built outbound UDP connection 376604 for outside.....
The %ASA-6-302015 is the message number. In config mode type:
no logging message 302015
You have to do this for every message you don't want to log.
itdsmartnet Wed, 11/26/2008 - 04:25
i only want vpn messages to be log. no other messages to be logged on syslog server.
Is there any way to log only specific messages and the rest of messages will not be logged.
John Blakley Wed, 11/26/2008 - 05:08
Unfortunately, not that I'm aware of. When you set your logging level, it logs everything from that level down. So if you set the logging level to 5, it logs 1 - 5 messages. You then have to tell it what messages you don't want to log.
lowen Wed, 11/26/2008 - 07:41
To minimize the number of messages that you have to disable, you can set the log-level to the most restrictive (7/alerts), and promote the messages that you want to see to that level:
logging trap alerts
logging message 302015 level alerts
lowen Wed, 11/26/2008 - 07:48
Oops! That would be level "emergencies" instead of "alerts" (numerically, 0 not 7). Also, you might want to look at the "logging list " command; if the classes map well to what you want to see, it may simplify things for you (I've never used it, but it looks like it might fit).
