Cisco Ace - Gracefully shut down rserver with SSL connections
Nov 26th, 2008
Hello
I run a ace module in a 6509
Version A2(1.2) [build 3.0(0)A2(1.2)
How do i gracefully shut down a rserver with current ssl connections?
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/command/reference/realserv.html#wpmkr1015382
In this dokument it says that the: no inservice command resets all ssl connections. I want to let clients finish their ssl connections, then take the server out of service.
Does it let the clients finish their ssl sessions, if i take the rserver out of service with the: inservice standby command under serverfarm > rserver instead?
as in:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/command/reference/servfarm.html#wpmkr1036418
If it does, I have another problem, i want do restrict what commands my webmasters can run, and they need to shut down a server grecefully but limit other commands. If i give there users any of the predefined roles or try to make a own role, a can't make them gain access to take a rserver out of service (no inservice or inservice standby command i missing) in a serverfarm...? but my admin user can run those commands.
Does anyone have a idea what role that work or if i make my own role what rules i should use?
Appreciate any help!
//Kristoffer
ciscocsoc Wed, 11/26/2008 - 07:57
  • Silver, 250 points or more
Hi Kristoffer,
The minimum required access is modify to real-inservice.
ace1/Test(config)# role SCOPED1
ace1/Test(config-role)# description Allow control of servers
ace1/Test(config-role)# rule 1 permit modify feature real-inservice
ace1/Test(config-role)# rule 2 permit create feature config-copy
ace1/Test(config-role)# exit
ace1/Test(config)# exit
Then create a user and associate it with the scope.
ace1/Test(config)# username adminScoped password ReallySecret role SCOPED1 domain default-domain
Roles are documented in the Virtualisation Guide and in the Command Reference.
Cathy
krilleorg Wed, 11/26/2008 - 23:40
doesn't seem to have that command:
do you know what relese it is supported in?
or any other useful page a can look at the software releses or development train?
//Kristoffer
