Unity Connection 1.2 and Unity Enterprise 4.0.4
Answered Question
Nov 26th, 2008
My client has two flavors of Unity running Connection 1.2 and Enterprise 4.0.4, they originally purchased Connection but it didn't intergrate with Lotus Notes, so thats when the Unity 4.0.4 came in, now we are approaching end-of-life and we need to upgrade to Unity 7.0/Call Manager 7.0 does anyone have a reference for this I've been looking at how to merge both Unity Databases to the 7.0 and cannot find it.
Correct Answer by Tray Stoutmeyer about 8 years 5 months ago
This link should have everything you need to go from UC 1.2 to UC 7.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/upgrade/guide/7xcucrug020.html
But I just realized you want to go from UC 1.2 to Unity 7.0 which is not a supported path. You can only go from Unity to UC and not the other way around. Hopefully I read your question correctly. If you are trying to upgrade to UC 7.0 then the link above is valid. If you are migrating form UC 1.2 to Unity 7.0 then I am afraid there isn't a path for that.
Tray
Overall Rating: 5 (1 ratings)
Correct Answer
Tray Stoutmeyer Wed, 11/26/2008 - 06:20
  • Cisco Employee,
Tray
e.giron Wed, 11/26/2008 - 06:35
I think this guide helped I saw that I can go from Connection 1.2 to Connection 7.0 using COBRAS, and I would have to upgrade Unity 4.0.4 to 4.0.5 in order to import that data to Connection 7.0
Thank you.
