Hi there,
not sure I understand the terminology you are using, AXL is used to talk to the CUCM, the interface is slightly different across releases, but this would not imply any changes on the CTIOS side, that is running GED188 to cover the overall CTI interaction with a UCCE solution.
Can you please clarify?
Riccardo
