How to upgrade the ROM: System Bootstrap, Version?
Answered Question
Nov 26th, 2008
Dear All,
I need to know how to upgrade the system bootstrap image on 6506-E with two rendundant sup32-ge-3b?
Thanks & Regards,
Igor.
Correct Answer by aghaznavi about 8 years 5 months ago
Before upgrading Verify the minimum amount of DRAM, flash memory and Boot ROM version necessary for the new software release. Check whether your switch supports the requirements. Refer to Release Notes for Catalyst 6000/6500 Series Switches in order to verify the requirements for the new software image.
Here is the link for Upgrade bootstrap image on 6500 series.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080116ff0.shtml#req
Overall Rating: 4 (1 ratings)
Correct Answer
aghaznavi Tue, 12/02/2008 - 11:41
  • Silver, 250 points or more
