CiscoWorks authentication page doesn't redirect properly
Nov 26th, 2008
Hello
I have LMS 3.0 installed. When I access from a remote PC, everything seems to work fine. However, when I try to access from the CiscoWorks icon on the server it is running, the following sequence happens:
- I open CiscoWorks and the authentication page appears
- I introduce the credentials and the page is redirected to a blank page with the following URL:
https://hostname/CSCOnm/servlet/com.cisco.nm.cmf.servlet.CsAuthServlet
- Then, if I reduce the URL to https://hostname, I am correctly redirected to LMS Portal.
Does anybody know what could be happening?
Thanks in advance
Joe Clarke Wed, 11/26/2008 - 08:48
Most likely, this is a browser issue. What browser are you using on the client vs. the server? Make sure the browsers are configured the same as well in terms of pop-up blockers, proxy, security settings, etc.
anasaizgarc Wed, 11/26/2008 - 08:50
Thanks jclarke. Both of the are IE Explorer, however I'll try to check the options in case any of them looks different.
Joe Clarke Wed, 11/26/2008 - 08:59
You might also try Firefox on the server to rule the browser out.
