Importing and Exporting ASA certificates
Nov 26th, 2008
Is there an option on the ASA to not allow installed certificates to be exported? When I go to import a identity cert, I'd like to make it so no one can export it.
smahbub Wed, 12/03/2008 - 07:22
You can export and import keypairs and issued certificates associated with a trustpoint configuration. The security appliance supports PKCS12 format for the export and import of trustpoints.
DJCanuck1_2 Wed, 12/03/2008 - 07:41
I realize you can do that, but my question was is there an option during certificate installation to prevent the certificates from being exported? One reason for this would be the installation of a public wildcard certificate and making it so the wildcard certificate could not be exported and used elsewhere.
