Gateway ---- Gatekeeper registration issue
Nov 26th, 2008
Anyone had an issue with a 3745 registering to a 3825 gatekeeper? I have other gateways working fine on the gatekeeper, but when I tried to add the next gateway, it does not what to register at all.
Network traffic is wide open. (can ping both ways)
Debug RAS showed it trying, but hard to tell what it was trying to say to the GK:
Nov 25 21:24:17: h323chan_chn_process_read_socket
Nov 25 21:24:17: h323chan_chn_process_read_socket: fd=2 of type ACCEPTED has data
Nov 25 21:24:17: h323chan_chn_process_read_socket: h323chan accepted/connected fd=2
The IOS that is working is on the gateway is:
Version 12.3(14)T7,
System Bootstrap, Version 12.3(11r)T2
The gateway that is not working is:
Version 12.3(11)T7,
System Bootstrap, Version 12.2(8r)T2,
Anyone seen something like this?
amith.kumar Wed, 11/26/2008 - 09:53
I had similar problem with 3745 gateway registering to a 3845 gatekeeper but the debug messages were not the same.
Have you tried doing a shut and no shut of the gateway?
config t#
config t#gateway
(gw)#no shut
Let me know what happens?
Tommer Catlin Wed, 11/26/2008 - 10:06
Thanks for the quick response!
I was a running a pilot last night so I had to roll it all back.
The current 3745 is connected to a PBX with a digital connection. Then it has dial-peers to other voice routers.
Do you know if I add the following commands:
interface Loopback0
ip address
h323-gateway voip interface
h323-gateway voip id XXX ipaddr 1718
h323-gateway voip h323-id [email protected]
h323-gateway voip tech-prefix 1#
Will it affect my existing dialing peers and serial interface? I would like to register the gateway and test registration, but affect the existing dial-peers or voice operations of the router.
Thanks much!
amith.kumar Wed, 11/26/2008 - 10:20
It is really hard to say it impacts as I haven't seen any impact in my lab previously. But since your is a production network it is always suggested to take extra precaution.
As far as I remember until you change the "session target" to RAS in your dial-peers (to find the IP address of the session target) it shouldn't affect your existing dial-peers
Tommer Catlin Wed, 11/26/2008 - 10:23
what does the No Gateway command actually do, is this just for Registration to gatekeeper on the gateway?
mikram Wed, 11/26/2008 - 10:54
Gateway command activate h323 process on the router and you can see it registers with GK. If you want to try, do
no gateway <---- on gateway
and debug h323 messages on GK
Gateway <------------ on gateway again
it should try to register with GK.
Tommer Catlin Wed, 11/26/2008 - 11:01
on a 3845, I can not do the commands above. I have ot tried with the 3745 yet
Tommer Catlin Wed, 11/26/2008 - 11:12
Ok, so on the 3745, it was odd, I added back in the H323 commands on the interface, did not register.
I went to config t
did a gateway
then exited
and sho gateway
and it registered.
Like a bug or something?
amith.kumar Wed, 11/26/2008 - 11:21
I had also looked through bug toolkit to find any known issues but couldnot find any. Anyway glad to hear it worked
Tommer Catlin Thu, 12/04/2008 - 13:21
Just to keep everyone updated, here is what I found.
The "No Gateway" and Gateway does actually work on 12.3 and 12.4.
Before you can register a gateway to a gatekeeper, you must build at least one dial peer. Dont ask me why, but I struggled with it and struggled... I had the correct commands in the interface for h323, but as soon as I built a dial peer, it registered.
I know, sounds goofy, but it worked. My thought process would be, first register, then build the dial peers. makes sense right? But with no dial peers, it would not even try to register. on 12.3 or 12.4.
jbarcena Thu, 12/04/2008 - 14:01
Is it a dial-peer to the Gatekeeper? Have you tried also with an IP Route?
Tommer Catlin Thu, 12/04/2008 - 14:05
The simple way to put this is:
If you have a new gateway or an existing gateway you want to register to a gatekeeper, you must first ensure you have a dial peer configured on the gateway.
Dial-Peer voice 800 voip
Now, go into your interface and add in the H323 commands to register to the GK.
interface Loopback0
ip address xx.xx.xx.xx
h323-gateway voip id GKa ipaddr 1718
mlitka Thu, 02/05/2009 - 13:33
I have an existing gateway with dial peers pointed to other gateways. When I registered the gateway to my gatekeeper calling using the existing dial-peers broke.
I thought that the call would only be directed to the gatekeeper when a dialpeer was configured with the session target ras statement.
Is this not correct?
Tommer Catlin Tue, 02/10/2009 - 13:26
If your Dial Peers are RAS dial-peers, then they would be directed to the GK. If they are something like target IP with an ip address, they will go there.
mlitka Tue, 02/10/2009 - 13:32
This isn't happening though. All the calls are sending RAS requests to the GK and failing. I don't even have a dial-peer setup with session target ras at this point. When I put the gateway statement in this starts happening. When I remove it it stops.
Tommer Catlin Tue, 02/10/2009 - 13:36
can you post part of your configuration? Also, what IOS level you are running on the GW
mlitka Tue, 02/10/2009 - 13:42
voice rtp send-recv
voice service voip
interface Loopback0
ip address 10.x.x.x
h323-gateway voip id acme ipaddr 10.x.x.x 1719
h323-gateway voip bind srcaddr 10.x.x.x
All of my POTS dial peers seem to be failing.
I am at 12.4(18) - Adv. IP Services
Chris Deren Tue, 02/10/2009 - 13:45
We need the dial peer configuration as well as the GK configuration.
Chris Deren Tue, 02/10/2009 - 13:36
Please post your configuration and the number you are trying to dial.
ALso, run the "debug gatek main 10" during the call on the GK and post output.
mlitka Wed, 02/18/2009 - 06:34
Chris -
Here is the Gatekeeper and Gateway configuration.
I can't provide debugs yet as I need to schedule another maintenance window.
mlitka Tue, 03/17/2009 - 06:39
I got this figured out with the help of TAC and thought I would share.
From TAC:
'Seems that you may be running into a feature that was designed to prevent toll fraud.
When the receiving gateway which is registered with GK gets an incoming call, it will check with the GK to see if that call was authenticated/authorized by the GK. If the GK is unaware of that call, the GK sends ARJ back to the GW and the call is not permitted.
You may be able to get around this by adding to the existing voip dial peers which route the calls back and forth between the gateways.'
The solution was to add
incoming called-number xxx
to my existing dial-peers. This allowed the calls to get through.
