11-26-2008 10:09 AM - edited 03-13-2019 05:53 PM
Is it possible to change the description field within the CM-SQL db programmatically to all phones within my cluster?
I know this can probably be done thru BAT, but I was asked to make an inquiry. Has anyone done this before?
I am asking because I have another db that pulls data from CM-SQL description field to populate tables within another db.
I think I know the answer to this question, but does TAC support this type of questionable activities?
Finally, is there any Consultant Groups that specialize in the type of programming work?
All Windows environment: Call Manager 4.1(3)sr3a with Unity 5.0(1.0) and Exchange 2003.
Sincerely, Tom
Solved! Go to Solution.
11-26-2008 11:23 AM
it is doable, but we do not support any kind of changes made directly in the DB
we do change stuff in the DB but to fix something, and this needs to be done either by the CSE himself or with a set of instructions provided by the CSE
java
if this helps, please rate
11-26-2008 12:31 PM
Hi Tom,
You can use AXL SOAP instead, and use updatePhone.
I know where you can buy a tool to do bulk AXL changes,
email me for details saschamonteiro@hotmail.com
11-26-2008 11:23 AM
java
11-26-2008 12:31 PM
Hi Tom,
