telnet to port 25
Nov 26th, 2008
Through our ASA we can telnet to a email server but get 500 5.5.1 Command unrecognized: "XXXX" when we try to use the commands. Any help would be appreciated.
Thanks.
sachinraja Wed, 11/26/2008 - 11:30
Hello spencer
You might really not have the right access for it.. ASA works on layer 3/4 and allows a packet on port 25. but as it hits the server , your communication is on layer 7 and the application decides what you have to do ! So, this is more to do with Application. If you can telnet to port 25 and till you arent timed out, I do not see this as a network issue
Hope this helps..
Raj
cisco24x7 Wed, 11/26/2008 - 11:35
"no fixup protocol smtp 25" and your mail will
work. It is a known issue with ASA/Pix and
mail
