Warning message
Jaime Valencia Wed, 11/26/2008 - 12:08
  • Cisco Employee,
  • Hall of Fame,
    2011
yes, go to the OS admin and use the upgrade interface to apply the patch
java
if this helps, please rate
hmglobcom Wed, 11/26/2008 - 12:18
So the patch includes all other files or will the system detect that its only a patch?
Jaime Valencia Wed, 11/26/2008 - 13:38
  • Cisco Employee,
  • Hall of Fame,
    2011
the patch might contain OS, FW, CSA, etc upgrades, refer to the RN to find out all info
but the way to apply them is thru the same interface you use to upgrade, the system will now what it is by the filename
java
