Issue with Network configuration - ACS 4113 Appliance
Answered Question
Nov 26th, 2008
We are having issues with two particular devices. I am trying to remove and add the devices, but when I do a search and go to their IP, I receive.
Failed to edit blahblah.ourdomain.... Reason: The Host no longer exists.
How do I get rid of this so I can readd the devices?
Dwane
Correct Answer by Daniel Laden about 8 years 5 months ago
how many characters long is the host name. If longer than 32, you will not be able to modify it in the gui. Use the CSUTIL to delete it. Recreate it with fewer than 32 characters.
Overall Rating: 5 (1 ratings)
Correct Answer
Daniel Laden Thu, 11/27/2008 - 11:21
  • Cisco Employee,
dpatkins Thu, 12/04/2008 - 12:57
I appreciate the help. That was it. 32 characters.
Removed them and readded a much smaller name.
Dwane
blittrell Wed, 05/26/2010 - 10:43
Looks like this is a the same issue here but I am on a SE box and Putty into it I do not see the option for CSUtil, any ideas if this is possible on a SE box?
