Fax machines do not receive with VG224
Nov 26th, 2008
I have fax machines from Pitney and Ricoh behind a VG224. The Ricoh unit will intermittently not receive...it rings but does not pick up or fails handshake. The Pitney unit gives a fast busy signal. The Ricoh has been adjusted to begin communications at 9600, but the problems still exist. What can be adjusted in the VG224 to support the fax communication?
Keith Fulcher Tue, 12/02/2008 - 05:24
It depends on which protocol you are using (SCCP, MGCP) but you should configure the Fax Passthrough commands. I would list them, but it varies per protocol.
Nicholas Matthews Fri, 12/12/2008 - 12:14
  • Red, 2250 points or more
First try normal voice calls by hooking up a normal analog phone and make sure that your problem is 100% related to faxing. If analog phones fail, you will need to troubleshoot a normal voice call.
If normal phone calls work fine, try adding these commands:
voice service voip
fax protocol none
modem passthrough nse codec g711ulaw
Nicholas Matthews Mon, 03/02/2009 - 14:55
Hi Doug,
MGCP:
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711ulaw
-nick
b.orth Tue, 03/03/2009 - 07:41
Hi Nick,
I am also having intermittent fax problems.
We have high volumes, usually 500 plus faxes per day. About every 2 weeks we get between 5 and 10 complaints of "incomplete" faxes. For instance: it should be a 10 page fax... we get 5 pages, but the sender does not get an error sheet. We are running CUCM 4.2(3).
Any ideas? or do you need more information?
Bob
Nicholas Matthews Tue, 03/03/2009 - 08:07
Hi Bob,
Very hard to say. You could have packet loss/jitter in your network, or slips on your T1s.
Those are you big ones.
You could also try disabling ecm:
no mgcp fax ecm
-nick
b.orth Tue, 03/03/2009 - 08:41
Hi Nick,
Funny that you mentioned T1's slips and packet loss/jitter, that is where I was starting to look for problems. I will keep a close eye on those.
I also noticed we can not set network clock on the VG224's like we do on 3845 gateways. Is that not necessary?
I am using fax pass through on the VG224's, and have "no mgcp fax t38 ecm".
In my version of code I do not see "no mgcp fax ecm".
Thanks for the tips, I will let you know about the T1's and network.
Bob
