User Tracking is unable to track some hosts after re-installation
Nov 26th, 2008
Currently, I have a problem to track some of my hosts using Campus Manager User Tracking. The host is shown in the User Tracking result before I did a re-installation.
To troubleshoot, I did a path analysis and found that the host is under unmanaged/inaccessible status. I have also attached the screen shot for the path analysis result. Please advise. Thanks
Joe Clarke Wed, 11/26/2008 - 20:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Before and end host can be acquired by User Tracking, the switch to which is directly connects must be Data Collected by Campus Manager, and show up with a green switch icon on the Topology Map. Is this the case?
Joe Clarke Wed, 11/26/2008 - 22:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
To troubleshoot this, you need to enable "user tracking" debugging under Campus Manager > Admin > Debugging Options > User Tracking Server. Then run a new UT acquisition. Then port the resulting ut.log; the show run, show ver, and show mac from the switch this missing end host directly connects; the port to which this end host directly connects; and the portsData.xml, vlanData.xml, and RouterData.xml files from NMSROOT/campus/etc/cwsi.
