BGP Notification Message
Nov 26th, 2008
We partner with other MPLS providers via NNI to offer MPLS connectivity to customers.
CPE Logs:
Nov 27 07:39:57.432 TOKYO: %BGP-3-NOTIFICATION: received from neighbor 10.101.63.146 6/6 (cease) 0 bytes
Nov 27 07:39:57.432 TOKYO: %BGP-5-ADJCHANGE: neighbor 10.101.63.146 Down BGP Notification received
Nov 27 07:40:00.835 TOKYO: %BGP-5-ADJCHANGE: neighbor 10.101.63.146 Up
CPE BGP Config:
router bgp 65555
no synchronization
bgp log-neighbor-changes
network 10.253.1.1 mask 255.255.255.255
network 192.168.8.0
neighbor 10.101.63.146 remote-as 10134
no auto-summary
Recently we have been getting this message in our CPE which connects to the PE of international provider from where MPLS cloud starts. We manage customer CPEs. Since we have BGP configured between CPE and PE we are getting this kind of BGP notification message. We have 2-3 other customers running static routes between CPE-PE where we are not getting any logs in CPE. But for all these CPEs, we are receiving BGP route reset in our management router which is also connected to the same partner's MPLS cloud just for management purpose. I strongly suspect the issue is with local loop(Between CPE-PE). We have done BERT tests on local loop, but didnt yield any result may be because the issue happens once in a day.
Anybody here experienced similar problems?? How to resolve this?
Thanks in advance
AneesH
Giuseppe Larosa Wed, 11/26/2008 - 23:55
  • Hall of Fame,
    Founding Member
Hello Aneesh,
depending on the platform you use for CPE you may need QoS to prioritize BGP packets exiting the interface during link congestion: usually you receive the BGP notification because the hold-time expired on the neighbor without seeing any BGP keepalive.
This can be caused by line errors but also by a congested link where BGP packets sit in a queue.
However, the subcode is cease and not expired:
Nov 27 07:39:57.432 TOKYO: %BGP-3-NOTIFICATION: received from neighbor 10.101.63.146 6/6 >>>(cease) 0 bytes
this points to the neighbor thinking of having received a not acceptable BGP packet.
Hope to help
Giuseppe
rajivrajan1 Thu, 11/27/2008 - 00:00
  • Bronze, 100 points or more
can u post
debug ip bgp neigh &
sh tcp brief
any port blocking ?
so all 170 tcp connection established ?
any authentication issue ?
milan.kulik Thu, 11/27/2008 - 05:05
  • Red, 2250 points or more
are you really using
router bgp 65555 ?
Or are you just masking the real AS number used in your config?
BR,
Milan
deshpande-s Sat, 11/29/2008 - 09:25
Hi Aneesh,
i am oberving the time to BGP Neighbourship come up that is only 3sec,however if there is any fluctuations then it takes atlest 240sec to eshtablish the session.
kindly confirm that whether BGP timers are configured on default basis.
kindly reply whether my suggestion is useful ot not.
