OSPF genral
Nov 27th, 2008
  • Bronze, 100 points or more
im stuck with OSPF again :( :(
im receiving default routes from two neighbours.
Both are having
same metric
same forwarding address
same cost [ sh ip ospf border]
but one path is selected - on what basis its selecting ?
Overall Rating: 5 (4 ratings)
Giuseppe Larosa Thu, 11/27/2008 - 05:34
  • Hall of Fame,
    Founding Member
Hello Rajveev,
may you post the output of
sh ip ospf database external 0.0.0.0
sh ip route 0.0.0.0
and
sh ip protocol summary
how many OSPF processes are involved, multiple OSPF processes are competitors to install routes in the routing table and don't share OSPF informations
Hope to help
Giuseppe
Richard Burts Thu, 11/27/2008 - 07:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Rajveev
Is it possible that one of the default routes is an external router while the other is an intra-area (or inter-area) route? There is an order of preference in OSPF in which intra-area is preferred over inter-area, which is preferred over external routes.
Rick
rajivrajan1 Thu, 11/27/2008 - 20:29
OSPF Router with ID (26.63.47.1) (Process ID 10)
Type-5 AS External Link States
Routing Bit Set on this LSA
LS age: 1101
Options: (No TOS-capability, DC)
LS Type: AS External Link
Link State ID: 0.0.0.0 (External Network Number )
Advertising Router: 10.10.0.1
LS Seq Number: 8000208E
Checksum: 0x43DB
Length: 36
Network Mask: /0
Metric Type: 1 (Comparable directly to link state metric)
TOS: 0
Metric: 20
Forward Address: 0.0.0.0
External Route Tag: 10
LS age: 737
Advertising Router: 10.10.0.2
LS Seq Number: 800017EF
Checksum: 0x9530
Length: 36
Network Mask: /0
TOS: 0
Metric: 20
LS age: 1167
Advertising Router: 10.63.63.1
LS Seq Number: 800047B0
Checksum: 0x9395
Length: 36
Network Mask: /0
Metric Type: 2 (Larger than any link state path)
TOS: 0
Metric: 1
sh ip route 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
Known via "ospf 10", distance 252, metric 69, candidate default path
Tag 10, type extern 1
Last update from 10.62.253.58 on Serial0/1/0, 00:00:27 ago
Routing Descriptor Blocks:
* 10.62.253.58, from 10.10.0.1, 00:00:27 ago, via Serial0/1/0
Route metric is 69, traffic share count is 1
Route tag 10
sh ip ospf border-routers | i 10.10.0.1
i 10.10.0.1 [49] via 10.62.253.58, Serial0/1/0, ASBR, Area 0, SPF 2469
sh ip ospf border-routers | i 10.10.0.2
i 10.10.0.2 [49] via 10.62.253.58, Serial0/1/0, ASBR, Area 0, SPF 2469
1.10.10.0.1 and 10.10.0.2 both are sending default routes
2. both are having same metric in routing table & border router table also
3.on what basis 10.10.0.1 is selected - i tried clearing the process still it's selecting 10.10.0.1 only.
4 . y not 10.10.0.2 ?
Giuseppe Larosa Thu, 11/27/2008 - 23:46
  • Hall of Fame,
    Founding Member
Hello Rajeev,
the physical outgoing link is only one to reach the two ASBR and it is a serial interface:
these paths are intraarea ( leftmost i)
From a forwarding point of view being both ASBR reachable out a single point-to-point link this behavior is correct: even if both routes were installed the forwarding path is only one.
let's see paragraph 16.4 of RFC2328 external routes calculation:
http://ip-doc.com/rfc/rfc2328#s100
10.10.0.1's LSA is older and entered first the OSPF DB.
To verify this do on router 10.10.0.1
clear ip ospf process 2429 (or whatover process-id you use on that node) the other LSA that via 10.10.0.2 should be installed or just wait over time when the LSA will be renewed by 10.10.0.1 (within 30 minutes half max LSA age)
Hope to help
Giuseppe
rajivrajan1 Fri, 11/28/2008 - 00:03
thanx Giuseppe let me check that.
