Giuseppe Larosa Thu, 11/27/2008 - 06:59
Hello Nav,
there is one or more processes that doesn't release memory
try to use
sh proc mem | inc Free
to monitor the amount of total Free memory over time.
Verify if there is any feature you can remove from the router.
Hope to help
Giuseppe
Richard Burts Thu, 11/27/2008 - 07:08
Nav
The symptoms sound like there is a memory leak (and the mention that you are running a deferred release supports that assumption). So in addition to the suggestions from Guiseppe I would suggest that you upgrade the software on the router to a more recent version, in which hopefully the memory leak is fixed.
Rick
