Unity with Failover - Move SQL DB
Nov 27th, 2008
All,
Can anyone recommend a procedure for this. We have a unity failover pair VM only running out of space on the C: drive. This is because during the installation the procedure to move the logs and DB to the D: drive was not performed. If I try to detach the databse now it does not succeed, because it is running failover I guess. Anyone know of the best way to get around this with minimal service disruption?
Martin
jasoninbtr Sun, 12/07/2008 - 13:45
Also, do this first on your passive node then failover and do it on the other node.
Jason
