ADSL Setup
Answered Question
Nov 27th, 2008
Hi All,
I have just configure an ADSL interface on a router to dynamically connect to BT network for internet connection.
Below is my running config:
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/38
dialer pool-member 1
protocol ppp dialer
interface Dialer1
description ADSL Interface
ip address DHCP
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
ppp chap hostname xxxxxxxxxxxxxxx
ppp chap password xxxxxxxxxxx
ppp pap sent-username xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Question:
1. Please How do I configure my Dialer1 interface to automatically request a DNS from the BT network?
2. Which do I need to configure on my Dialer1 interface, is it "ip address DHCP" or "ip address negociated"
3. Do I need to configure an "ip nat pool"?
Cheers!
Correct Answer by lejoe.thomas about 8 years 6 months ago
Hi Law,
Guiseppe, there is an access-list misconfiguration for NAT, the correct access-list would be
access-list 100 permit ip 192.168.0.0 0.0.255.255 any
This will permit all address from major networks to be NAtted to the public address.
192.168.1.0/24
192.168.2.0/24
192.168.3.0/24
192.168.4.0/24
192.168.5.0/24
Remember I gave you that access-list (currently in your config) previously as an example.
Also make sure you set your DNS server on the PC and give it a go.
Lejoe
Overall Rating: 5 (2 ratings)
lejoe.thomas Fri, 11/28/2008 - 00:25
  • Silver, 250 points or more
Hi Lawrence,
1)Please How do I configure my Dialer1 interface to automatically request a DNS from the BT network?
ppp ipcp dns request
ip address negotiated
Yes you'll need to configure NAT
Steps
1) Configure your LAN interface as
ip nat inside
2) Under the dialer interface
dialer-group 1 (assign the dialer interface to dialer group
All in global configuration
3) Configure access-list to specify traffic that will be NAT-ted. Assuming your LAN range is 192.168.0.0/24
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
ip nat inside source list 100 interface dialer 1 overload
4)Specify interesting packets that can trigger a call
dialer-list 1 protocol ip permit
5) Add a default route to point everything through the dialer interface
ip route 0.0.0.0 0.0.0.0 dialer 1
Lejoe
sr2470182 Fri, 11/28/2008 - 01:59
Dear Lejoe,
Thanks very much for your time! Its well appreciated.
Please find below, my new config. I have done exactly as you directed.
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap password 0 xxxxxxxxxxx
ppp ipcp route default
ppp ipcp address accept
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 100 interface Dialer1 overload
Question:
1) As you can see in the above config, do I need the following on the dialer 1 interface?
dialer pool 1
Or I should delete them.
2) Why using Access-list 100 and not Access-list 1.
Law
lejoe.thomas Fri, 11/28/2008 - 15:52
Hi Law,
dialer pool 1
Yes you need all the above in your dialer interface configuration. Since you're automatically inserting a dynamic default route through IPCP negotiations (ppp ipcp route default), remove the line
For specifying the traffic (internal LAN range) that will NATed, an extended access-list is used. Extended access-list begins from 100, which can deny or permit packets based on source and destination address, port numbers and upper layer protocols allows greater control and flexibility. Please note that this number (100) is referenced in the statement
A standard access-list which begins at 1, allows only to permit or deny based on source address or the entire TCP/IP protocol suite. We could also use a standard access-list to specify the NAT traffic, but I mostly prefer extended ACLs because of the control.
Lejoe
sr2470182 Sun, 11/30/2008 - 10:37
Thanks Lejoe,
I have the following interface on the router:
interface FastEthernet0/0
description LAN Interface
ip address 192.168.2.1 255.255.255.0
ip nat inside
duplex auto
speed auto
Question:
1) If I should connect a PC configure for 192.168.2.2/24,to the above interface, will I be able to brouse the internet?
2) Do I have to configure an internal DNS on the router to be able to brouse the net fron my internal pcs?
3) Does it mean that the two commands below are same, hence I should remove one?
Thanks a miilion
lejoe.thomas Sun, 11/30/2008 - 14:01
No, since are you're not running DHCP, you'll have to configure default gateway and DNS on the PC before you can browse.
default gateway : 192.168.2.1/24
DNS Server : ISP obtained
Yes, DNS is required. You can configure DNS address the same as that you obtain from your ISP on the PCs.
(obtains default route dynamically through ppp/ipcp negotiations)
(statically setting a default route)
You can remove either of the above lines.
Lejoe
sr2470182 Mon, 12/01/2008 - 06:29
Thanks Lejoe,
Finally I can ping the internet from my router (i.e ping www.yahoo.com). But I can NOT browse from my internal network, which is connected to the interface f0/0
Please do I need a static NATing? or what can I do to be able to browse the net from my LAN?
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/2/0
switchport access vlan 2
interface FastEthernet0/2/1
switchport access vlan 3
interface FastEthernet0/2/2
switchport access vlan 4
interface FastEthernet0/2/3
switchport access vlan 5
interface ATM0/1/0
no ip address
pvc 0/38
protocol ppp dialer
interface Dot11Radio0/3/0
no ip address
encryption mode ciphers aes-ccm
ssid xxxx
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
channel 2412
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
interface Vlan2
description USER VLAN
ip nat inside
interface Vlan3
description SERVER VLAN
ip address 192.168.3.1 255.255.255.0
ip nat inside
interface Vlan4
description TRAINING VLAN
ip address 192.168.4.1 255.255.255.0
ip nat inside
interface Vlan5
description DMZ VLAN
ip address 192.168.5.1 255.255.255.0
ip nat inside
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ip http server
control-plane
gateway
timer receive-rtp 1200
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
Law
Giuseppe Larosa Mon, 12/01/2008 - 07:16
  • Hall of Fame,
    Founding Member
Hello Law,
you may need to add manually the ISP DNS server on your PC LAN settings.
I see that you are not using DHCP so the PC has to be configured manually with a default gateway = 192.168.1.1 and with a DNS server.
Hope to help
Giuseppe
sr2470182 Mon, 12/01/2008 - 08:19
I have got a DHCP/DNS server on my LAN.
I have configuremy PC with static IP and using 192.168.2.1 as my GW. Yet I cannot browse the net.
May be I need to configure an IP NAT Pool (name), using my the IP Addreses that my ISP gave to me.......I don't know.
ohassairi Mon, 12/01/2008 - 09:05
i think f0/0 belongs to vlan1. why you don't give the IP address 192.168.2.1 to vlan1 instead of f0/0
lejoe.thomas Mon, 12/01/2008 - 13:43
Hi Law,
The issue of browsing is merely related to DNS. You have already configured NAting on the router, so most of your configuration on the router is correct.
Since you said you run an internal DHCP/DNS server, what I would suggest is
On one of your computers in the internal LAN, get details such as default gateway, DNS.
1) Verify the default gateway is indeed the f0/0 int of the router
2) Verify the DNS server is the address of the internal server
3) Ping the default gateway and DNS server
4) Verify the DNS server, which might be mostly configured as a forwarder is correctly forwarding name resolution queries to a public DNS server.
Lejoe
sr2470182 Tue, 12/02/2008 - 08:23
Thank you all for all your efforts in helping to solve my problem. However I have tried all your suggestions but no luck yet.
Below is my "sh ip route" when connecting the router to the internet:
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 217.47.30.74 to network 0.0.0.0
81.0.0.0/32 is subnetted, 1 subnets
C 81.135.169.26 is directly connected, Dialer1
217.47.30.0/32 is subnetted, 1 subnets
C 217.47.30.74 is directly connected, Dialer1
C 192.168.2.0/24 is directly connected, FastEthernet0/0
S* 0.0.0.0/0 [1/0] via 217.47.30.74
Again I can ping the internet from the router but I cannot browse the net (from my PC) whenever I connect to the f0/0 interface.
lejoe.thomas Tue, 12/02/2008 - 14:52
Hi Law,
Please host the output of the following commands
show host
show running-config
Lejoe
lejoe.thomas Tue, 12/02/2008 - 20:54
The show host, will show you the address of the name-server. Use this address as the dns server on your PC and try if things work.
Lejoe
sr2470182 Wed, 12/03/2008 - 01:43
Thanks Lejoe,
#sh hosts
Default domain is not set
Name/address lookup uses domain service
Name servers are 255.255.255.255
Codes: UN - unknown, EX - expired, OK - OK, ?? - revalidate
temp - temporary, perm - permanent
NA - Not Applicable None - Not defined
Host Port Flags Age Type Address(es)
As you can see above, nothing is shown in the "sh host" command.
Question:
Do I need to configure a static name-servers (of my ISP) on the router?
Also attached is the running-config.
Giuseppe Larosa Wed, 12/03/2008 - 03:02
  • Hall of Fame,
    Founding Member
Hello Law,
I think there is a little config mismatch in NAT
but f0/0 uses
192.168.2.0/24
so nat is never triggered
you can check nat with
sh ip nat translations
sorry I didn't see before
Hope to help
Giuseppe
sr2470182 Wed, 12/03/2008 - 03:19
Thanks Giuseppe,
when I type in "sh ip nat translations", nothing is shown or displayed.
Though the router is not connected to the internet right now. I mean no adsl cable is connected to the interface.
What do you suggest the correct NAT statement should be If you feel there is a mismatch in the config?
Correct Answer
lejoe.thomas Wed, 12/03/2008 - 03:36
Hi Law,
192.168.1.0/24
192.168.2.0/24
192.168.3.0/24
192.168.4.0/24
192.168.5.0/24
Lejoe
sr2470182 Wed, 12/03/2008 - 03:50
Thank you all. I very much appreciate all your help.
I have now changed the list to
I will give it a go and inform you what happen.
Regards to you all,
lejoe.thomas Wed, 12/03/2008 - 03:58
No worries, It's been long as length of this thread would indicate that you've been running behind the problem. Hopefully this should resolve things :)
Please get back if you run into any problems.
Lejoe
sr2470182 Wed, 12/03/2008 - 07:31
I am now Up and Running!!!
Thank you all for your support.
