1252 autonomous to LWAPP
Answered Question
Nov 27th, 2008
I can't seem to find the image for upgrading a 1252 from autonomous to LWAPP. Please can someone point me in the right direction?
Many thanks.
Correct Answer by wesleyterry about 8 years 7 months ago
Copy this whole link and try it out (pasting isn't exactly making the whole thing one link): http://tools.cisco.com/support/downloads/go/IPCheck.x?defAdv=N&sftAdv=N&image=c1250-rcvk9w8-tar.124-10b.JA3&filepath=/swc/esd/02/crypto/3DES/281235915/guest&filename=c1250-rcvk9w8-tar.124-10b.JA3&advUrl=null&isk=Y&defInd=N&mdfid=281235915&sftType=Autonomous%20To%20Lightweight%20Mode%20Upgrade%20Image&optPlat=&relVer=12.4(10b)JA3&fileId=271159&treeMdfId=278875243&treeName=Wireless
Or search cisco.com for c1250-rcvk9w8-tar.124-10b.JA3
I think this is what you are looking for.
Overall Rating: 5 (1 ratings)
Correct Answer
wesleyterry Thu, 11/27/2008 - 13:26
  • Bronze, 100 points or more
andrew.harmse Fri, 11/28/2008 - 03:33
I couldn't get the link going, but the search delivered the goods. One thing though, I couldn't use the upgrade tool with the image - it chirped something about it not being a valid recovery image. I then did it from the command line of the AP and that did the trick.
Many thanks.
Andrew
Scott Fella Fri, 11/28/2008 - 07:18
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
The upgrade tool doesn't support the 1250 access point that is why you got errors. CLI is the only way it can be done.
duncan.hambly Mon, 12/01/2008 - 06:50
Hi guys,
Wonder if anyone can help... I have the same issue with a 1242 AP. This may be a dumb question, but how do I upgrade via CLI?
I've tried the upgrade command which doesn't seem to be accepted by the IOS and I have tried simply uploading the software via tftp. The software uploads fine, but it seems to be far to large compared to the autonomous software.
Any help much appreciated.
Cheers,
D.
brodierad Sun, 11/30/2008 - 17:05
I couldn't find it either. Link seems to be broken in the Cisco software download site. Thanks for the info.
MICHAEL SCHROEDER Tue, 12/02/2008 - 12:58
Hi All, with APs with MIC inside (1130, 1240, 1250) you are able to do the Migration with an directly TFTP Download of the Migration Image and a reboot. You do not need the Migration Tool. Check the Release Notes. Regadrs, Michael
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
