Jaime Valencia Thu, 11/27/2008 - 10:51
  • Cisco Employee,
  • Hall of Fame,
    2011
modify the T_302 parameter which is the interdigit timeout
java
if this helps, please rate
Jaime Valencia Thu, 11/27/2008 - 11:00
  • Cisco Employee,
  • Hall of Fame,
    2011
CUCM service parameters
java
leandro.perez Thu, 11/27/2008 - 11:37
well friend I can't find this option in the UCM ver 6.1.2.9961-1
Jaime Valencia Thu, 11/27/2008 - 11:44
  • Cisco Employee,
  • Hall of Fame,
    2011
of course it's there
T302 Timer
let me guess, you never tried the advanced options????
java
allan.thomas Thu, 11/27/2008 - 12:20
  • Blue, 1500 points or more
Hi Leandro, the T.302 timer is a hidden service parameter and that is why you are unable to see when you scroll through the list of CallManager Service Parameters.
As Java mentioned it will definately be there but it will be hidden (+5 for you). Take a look at this taken from the CUCM 6.x Admin Guide:-
Some services contain service parameters that should rarely be changed. Cisco Unified Communications Manager Administration does not automatically display these parameters when you access the Service Parameter Configuration window. To view all parameters, click Advanced. After all parameters display, you can redisplay the basic parameters by clicking Condensed. If the Advanced button is disabled, all parameters for that service display by default.
Taken from this document link:-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmcfg/b02svprm.html#wp1024833
Hope this helps.
Allan.
