stations do not authenticate, possible bug cscsd52663
Nov 27th, 2008
customer have a cisco secure acs release 4.2(0) build 124 patch 5 installed in a windows 2003 under netbios domain "bsbr" (fqdn
stations from this domain have sucess on authentication
users from this domain have sucess on authentication
there is another netbios domain "sac" (fqdn that have trust relationship with domain "bsbr"
users from domain "sac" have sucess on authentication
STATIONS from domain "sac" do NOT have sucess on authentication
a time ago the customer was running the acs version 4.1, were advided to upgrade to version 4.2 because of bug cscsd52663, but after the upgrade the problem still the same
mbadali Wed, 12/03/2008 - 07:57
Sounds like this may be a cross forest auth issue. Check to see if the two domains are in different forests or the same forest.
Here are some URLs that will guide you through the install process. Ensure that they are followed exactly. There is a requirement to have the ACS services started as a domain admin account. I confirmed with TAC that as long as the account is a domain account with the proper permissions (in the doc) you'll be alright. I'm currently running ACS 4.2 with machine auth working successfully across forests.
Windows Authentication Configuration- Configuring for Member Server Authentication:
Release Notes for Cisco Secure ACS 4.2:
As discussed here is the bug:
CSCsd52663 : Cross forest user/machine authentication does not work
Machine authentication may fail due to "host not found".
ACS is installed on a server that's a member of a domain in Forest 1, while pc's performing machine authentication are members of domains in Forest 2.
Ensure ACS is a member of the same forest as the authenticating PCs.
Version 004.000(001.027)
To be fixed in 004.002
Apply to 004.002(000.105) 004.001(004.013.001)
Integrated in
Verified Release 004.001(004.013.001)
