FAX Server
Nov 27th, 2008
Question on Fax server. i have a client wanting a fax solution, having read the faxright guide it mentions fax boards, i'm a little confused. the client has H323 gateways integrated with callmanager version 6.1, i presumed the fax server would integrate with callmanager via IP and then into exchange. the question is do i need fax boards as i will not be connecting PSTN circuits directly into the fax server, or have i totally mis understood the application ? can somebody help me with this.
Zin.Karzazi Fri, 11/28/2008 - 01:47
No need for Fax boards. You have two option:
-Your Fax server will connect via IP directly to the Gateway using dial peers
OR
- to the Callmanager as an H323 Gateway.
