IPSec VPN Ports/Protocol
Answered Question
Nov 27th, 2008
I want to fine tune our firewall, for that I need to allow IPSec VPN traffic in firewall. Can anyone tell me the exact IPSec Ports & Protocols? Our VPN device resides behind firewall and using IPSec over UDP.
We are using Cisco ASA 5500 series as a VPN server.
Correct Answer by ajagadee about 8 years 6 months ago
ISAKMP - UDP 500
ESP - Protocol 50
ISAKMP NAT-Traversal - UDP 4500 (NAT-T)
IPSEC Over UDP - UDP 10000 (Default)
IPSEC Over TCP - TCP 10000 (Default)
Arul
*Pls rate if it helps*
Overall Rating: 5 (3 ratings)
Fernando_Meza Thu, 11/27/2008 - 19:12
  • Gold, 750 points or more
For that you might need to allow UDP 500 also you might also need to allow ESP (protocol 50)
Assuming your VPN head end device uses a routable (public) IP address then you only need to allow the above ports, otherwise you will have to use static NAT.
what is your scenario ?
Correct Answer
ajagadee Thu, 11/27/2008 - 21:07
  • Cisco Employee,
ISAKMP - UDP 500
ESP - Protocol 50
Arul
I have been search for this for a quite long time, but never got a firm answer.
Cisco VPN client on-line help says: IPSec over UDP - this port is negotiated and can not be changed - but never able to find any mention of how it is negotiated.
Looking at Sniffer packets - beside UDP 500, Sometimes UPD 62515, and other time UDP 62514 was used. UDP 10000 was never used.
