IPCC Express 2 Place Calls connecting
Nov 27th, 2008
  • Silver, 250 points or more
For one reason or another I need to write an IPCC Express script that places 2 calls, and then I want to merge the streams together, ie connect to the 2 calls. Anyone ever done this? Its not working like I thought it would. If its not possible anyone ever done something like this with CUAE?
Chad
Jonathan Schulenberg Fri, 11/28/2008 - 07:06
  • Cisco Designated VIP,
    2017 IP Telephony
Unfortunately you can't do it using the steps in the CRS editor. You can initiate two separate calls but there's no way to merge them together.
Chad Stachowicz Fri, 11/28/2008 - 14:03
Thats pretty grim... What API's would I be looking at to custom code this?
Chad
