allan.thomas Fri, 11/28/2008 - 04:51
  • Blue, 1500 points or more
CallerID is supported on H.323 with any version of CallManager, however as far as I know this is not the case for CallerID NAME.
If you require called-ID name, then you will require MGCP. The problem is that CCM
requires the called-name information delivered to it in the Display IE field and
almost all telco's send it in the Facility IE.
The other aspect to be aware of, is the caller-id is not supported for FXO modules controlled by MGCP, whereas H.323 does.
Hope this helps
Allan.
robray_sc Mon, 12/01/2008 - 10:08
Also your router needs to be a 2800 or 3800 series router to run IOS 12.4(20) and higher
-Robbie
whilenski Mon, 12/15/2008 - 08:38
If you are using a 3700 series chassis, Caller ID with name was implemented with 12.4(11)XW.
