IDSM (6.2) integration with ACS SE(4..0)
eduardo.mohr
Hi, I need to configure the module IDSM-2 in ACS to integrate with CSM, someone knows how to do this setup?
ACS: 4.0 Solution Engine
IDSM-2: 6.2
CSM: 3.2
Thank you
Not applicable
Perform the following tasks to configure IDSM-2:
1. Configure the Catalyst 6500 series switch for command and control access to IDSM-2.
2. Log in to IDSM-2.
3. Configure the switch to send traffic to be monitored to IDSM-2.
• Configuring the Catalyst Series 6500 Switch for IDSM-2 in Promiscuous Mode
• Configuring the Catalyst Series 6500 Switch for IDSM-2 in Inline Mode
• Configuring the Catalyst Series 6500 Switch for IDSM-2 for Inline VLAN Pair Mode
• Configuring EtherChannel Load Balancing
4. Initialize IDSM-2.
Run the setup command to initialize IDSM-2. During setup, you can configure the interfaces of IDSM-2
5. Create the service account.
6. Perform the other initial tasks, such as adding users, trusted hosts, and so forth.
7. Configure intrusion prevention.
8. Perform miscellaneous tasks to keep IDSM-2 running smoothly.
9. Upgrade the IPS software with new signature updates and service packs.
10. Reimage the application partition and the maintenance partition when needed.
For more information refer the below URL:
http://www.cisco.com/en/US/docs/security/ips/5.1/configuration/guide/cli/cliIDSM2.html#wp1030683
Ty for trying to help but the IDSM-2 is true, and I just need to make the AAA's of IDSM-2 by ACS, and integration with CSM I already know how to do ...
Please ........ you can integrate the IDSM-2 to the ACS?
Thank you
anyone???
