ISDN - Layer 2 Drops - Any way to automatically reset ISDN
Nov 28th, 2008
I have an ISDN connection that on occasion loses Layer 2 connectivity. The telco cannot find anything wrong and we have replaced the ISDN BRI module.
Is it possible to configure the interface or script something that monitors the L2 status and resets the ISDN interface automatically when it fails ?
The router is a 3745 acting as a voice gateway.
Thank you in advance.
Roger Norton.
Giuseppe Larosa Fri, 11/28/2008 - 15:24
  • Hall of Fame,
    Founding Member
Hello Roger,
you could build a script with a polling logic that:
a) issue show isdn status, parses its output
b) if L2 ISDN is fine does nothing else perform a shut/ no shut cycle
the correct state is :
a TEI assigned, state MULTIPLE_FRAME_ESTABLISHED
For example you could use EXPECT that is now included in activetcl at
www.activestate.com
or other scripting library of your choice
Hope to help
Giuseppe
