PIX UPGRADE FAILED
Nov 28th, 2008
hello, on a PIx 515
when i try to apply the upgrade procedure i have this message :
Received 2193408 bytes
Cisco Secure PIX Firewall admin loader (3.0) #0: Tue May 21 08:26:10 PDT 2002
Flash=i28F640J5 @ 0x300
BIOS Flash=AT29C257 @ 0xd8000
An internal assertion check has failed.
Copy the following message exactly as it appears,
along with any visible version strings, and
then call your support representative.
assertion "addr < STRATA_CHIPSIZE" failed: file "../flash/strata.c", line 222
Rebooting....
i'am stuck in it. do ypu have any ideas ?
ajagadee Fri, 11/28/2008 - 05:56
Based on the error message, it looks like your Flash Memory is corrupted and most likely need to replace the chassis.
Please open a TAC Case and they should be able to RMA you a new chassis provided the existing chassis is under warranty.
Arul
*Pls rate if it helps*
